I have a three monitor setup. If i use all 3 monitors as one or use Xinerama i cannot use Marking Menu nor Hotbox Submenus because the "middle" of the submenu pie will jump in position. It works well with 2 Monitors as one or Xinerama. But a third device will produce this bug. Is there a way to get around this, maybe some config settings?
The bug is only related to pie submenues and rmb submenues - hotbox menu submenues work fine.
Bad qt coding?
Thank you for the info. I do have an AMD FirePro W7000 card... there is no option for "absolute" or "left of" in the drivers. Can you post or privat msg me your /etc/X11/Xorg.conf file? So i can figure out what specific setting it is, and adopt it to my xorg.conf and of course post a solution for everyone who has this problem.
Ah ok, I see. Unfortunately I don't have any experience with ATI cards. I'm also not sure wheter my xorg.conf will help you, because as far as I can tell the screen mapping settings are nvidia-specific. Nonetheless you can obtain my xorg from this post.
If it doesn't help maybe try to ask the Autodesk support. When I confronted them with the issue they didn't know about it, nor did they have a solution, but as soon as I had discovered a way it works I sent them the solution as well. Maybe they investigated into this issue and can provide further help.
If nothing helps, just try to reset your driver settings to default or mess around with the monitor placement settings 🙂
Good luck!
