Installation & Licensing
Maya extension and Vray plug-ins...
3 REPLIES 3
kintaro_takanori
4251 Views, 3 Replies
Hello world 🙂
I would like to ask if anyone has the same issue. i have installed the extension version of maya 2013. also i have installed vray but they wont load in maya. is maya extension 2013 a fully functional version of maya? or do i have to install maya 2013 and then the extension? vray works in maya 2013 but wont appear in maya extension 2013.
thank you so much for the help! much appreciated
greets timi : D
be the best you can be...
3 REPLIES 3
santd
in reply to: kintaro_takanori
Thank you for posting on The Area forums,
Maya 2013 and Maya 2013 Extension 1 (a.k.a. 2013.5) are two different builds. Plug-ings that worked in Maya 2013 need to be recompiled to work in Maya 2013 Extension. This is most likely why the vray plugin is workin in Maya 2013 but not Maya 2013 Extension. There is information in the Maya 2013 Extension readme stating that it is a new build.
In doing some looking around I was not able to find a new build of vray that would work with Maya 2013 Extension unfortunately.
You can still download the latest fixes for Maya 2013 with the following service pack. However, you will not have the new features that the extension has:
http://usa.autodesk.com/getdoc/id=DL20537489
I hope this information is helpful.
Cheers,
David Santos
kintaro_takanori
in reply to: santd
Hey 🙂
Thank you for the help. Ohh now i see. So it boils down to that maya 2013.5 is a sepetate build. I
Thats ok. It still works with 2013 🙂 i just wanted to have 1 maya, 1 vray and 1 dx11 viewport 😉 hopefully vray 3 will be integrated with 2014?! Now that would be killer 😉
Greets timi
Sent from my iPhone
santd
Glad the information I sent was helpfu. Unfortunately, V-Ray is not intergrated directly into Maya 2014. However, Chaos Group has a release of V-Ray that supports Maya 2014. I found the following information in regards to that:
http://www.chaosgroup.com/en/2/news.html?single=553
Cheers,
David Santos
Administrator Productivity
