Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
Installation - Hardware - OS
Active Member
danmihaila.e
Re: Maya crashes on startup - Windows 7
07-14-2013 07:31 AM in reply to: danmihaila.e
Question: While trying to fix the issue I reverted my graphic card driver back to the previos one (320.18). Can I safely install the latest one (320.49).
Can some1 please confirm that this driver works and won't screw Maya again?
Thanks in advance!
Cheers!
Dan
Please use plain text.
Member
Russter11
07-14-2013 08:02 AM in reply to: danmihaila.e
Hi Dan, I currently have 320.49 installed and Maya has been working fine with Nelson's bit of code. You should be able to go ahead an install this one without running into any problems. -Brian
Active Member
danmihaila.e
07-14-2013 09:01 AM in reply to: Russter11
I can confirm that indeed, there is no problem if you install the latest driver!
Thank you so much again!
Member
adrian_adams
07-26-2013 01:27 PM in reply to: Russter11
This is all what's needed to be done?!? OMG THANK YOU!!! I have been going crazy over this!
Member
jlerogue
07-31-2013 05:56 PM in reply to: Russter11
This did not work at all for me.  I'm at my wits end with installing Maya 2014 on Windows 8.  My 2010 install works great.  Installs without a problem.  As for 2014, I had already installed/uninstalled four times, trying something different in-between installs.  I always get the 0xc000007b error upon attempting to start Maya.  I have:
Uninstalled Everything Autodesk:
Uninstall Programs didn't work, so I followed Autodesk's instructions for uninstalling from Windows:
    Uninstalled all peripheral apps (each seemed to uninstall)
    deleted %TEMP%../Local/Autodesk
    deleted %TEMP%../Roaming/Autodesk
    deleted c:\ProgramData\Autodesk
    deleted c:\Program Files\Autodesk
    deleted c:\Program Files\Common Files\Autodesk
    edited registry, removed HKEY_LOCAL_MACHINE\Software\Autodesk
    edited registry, removed HKEY_CURRENT_USER\Software\Autodesk
    disabled Symantec
    rebooted
Even after all that, between each uninstall, the uninstalls are never 100% complete, so I actually have to back-level to a restore point.  In addition, I have also tried the following:
deleted MSCVR100.dll from windows\system32 and replaced with Autodesk's x64 MSVCR100.dll
reinstalled VC++ 2012 x64 and x32 distributable
Deleted c:\windows\system32\d3dx*.dll and reinstalled (DirectX installs w/ Maya 2014)
Used Microsoft Uninstaller Clean-up utility to remove from Installed Programs list.
edited Registry for 1402 error, taking permission of "components" key
Added MAYA_DISABLE_CIP=1 to my 2014-x64\maya.env (which, incidentally, no such directory was there, so I created it, copying an earlier 2010 install.)
Please help.
New Member
coolbro15
08-20-2013 05:05 AM in reply to: Russter11
Im having the same issue....however it is with windows 8....everytime i go to load it i will get a fatal error crash.
My specs include
I5 3.4 processor
16gb ram
Nvidia gtx 760 2mb video card with latest update.
Is there a solution to this issue ?
Member
TwylaFox
08-27-2013 07:26 AM in reply to: Russter11
I'm having the same issues.
Worked fine a month or so back when I first installed then, out of nowhere, any AutoDesk product apart from Fcheck crashes on start-up.  Wiped everything and did a clean install of Maya 2014 - same result.  Wiped everything again and did a clean install of Maya 2013 - same result.  nVidia drivers 314.07 and 320.49 - same result all four ways.
System Information
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Processor: AMD FX(tm)-8350 Eight-Core Processor            (8 CPUs), ~4.2GHz
Memory: 32768MB RAM
Available OS Memory: 32712MB RAM
Page File: 7958MB used, 24695MB available
DirectX Version: DirectX 11
Display Devices
Card name: NVIDIA GeForce GTX 560 Ti
Chip type: GeForce GTX 560 Ti
Display Memory: 4047 MB
Dedicated Memory: 1999 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Samsung 27" LED
Monitor Model: S27B550
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Model: S27C230
Output Type: HDMID3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
New Member
bsyoon
09-16-2013 03:45 AM in reply to: Russter11
I had the same problem when I was installing motion builder, too.
Following solution worked for me.
http://www.harrycaskey.com/disable-autodesk-customer-involvement-program-cip/
