I have been trying to install maya for a couple days now.
Every time i do it starts installing but about 5 mins later the instalation finishes saying that some products failed to install. In this case all of them.
Im installing maya 2015, ive used the browser download and the regular installer same result. Im running windows 7 with plenty of room in the hard drive. Ive tried completely purging anything maya related from my system and trying again, not sure if i missed something or what.
Any help would be appreciated
Hello!
If you could both please provide your installation log files as attachments we'll be able to determine the exact failures. Thanks!
I fixed my problem and successfully loaded Maya 2015. Here are the steps I took:
1. Turn off Windows Firewall
2. Turn off virus protection
3. Switched browser from Chrome to Firefox which resulted in the download working and the installer loading.
4. The installer did say it would take a day and a half to load. So, I stopped the installer
5. Unplugged my modem for ten seconds and replugged it in and waited for it to initiate.
6. Redid the process from the autodesk page.
It downloaded in about an hour.
Hope this helps someone.
Hi @Anonymous and welcome to the Autodesk Community!
Check out this Autodesk Solution how to find your request code. Thanks!
Hi @Anonymous!
Did you by chance check the Accepted Solution listed in this thread? Did that help at all or did you see any changes? Please let us know. Thanks!
