Yet, When i had Maya 2015 earlier. I accidenataly deleted a file to it and it wouldnt run, so i tried to delete every file since when i tried to re-install it it says it has installed? So i was curious. I deleted stuff in: Program Files, Program Files (x86), Documents i tried everything. If you could tell me if there is a soultion since i cant normally install it. I was appreciate that.
Windows 64 bit, 4 gb Ram, AMD E2-1800 APU with Radeon(tm) HD Graphics card.
I'm having the same issue with a barnd new install myself. I had 2010 but am required to use 2015 for class. It's so frustrating. My first project is due tom and I can't do a thing.
I am having the same problem. I searched through forums and tried as much as I could. I finally got Maya 2015 to install but Mental ray and DirectConnect will not install. My class requires it as well and the technical service at my school had problems and said it would possibly take a week. I ran chkdsk /r and sfc /scannow, made sure visual c++ isn't an issue and I can not pinpoint the error. It totally sucks.
I have an idea which is not very appropriate but it will definitely work!!
First you have to install any virtual machine software in your computer...Eg: VMware....
Second you have to install same windows or operating system in which u are working on...
Once u have installed your operating system u can install maya in it...
It will surely work but it will affect your system speed for some time............................
I am teaching a Maya class at my Middle School and when my students try to download Maya at home they get this message
Any ideas?
Thank you
Hello @kganevsky!
As this is typically caused by system / Microsoft errors, your students will need to view the installation log to see specifically what's going on. They can find the log by clicking on the linked installation log file shown in your screen shot below, or by the following instructions.
Location of the log files generated by the installation of an Autodesk product
Once they have it open, I find the easiest way to find the root cause is to search for the word 'failure' and see what it's connected to.
The most common issue as well as the corresponding solutions can be found below.
Error 1603 during installation of Autodesk software
Ok.
We will try this. From what I have read most problems are because of
temp files that are full
not enough room on the hard drive
not enough RAM
Would you agree?
Thank you
While those can be potential issue drivers, I do not think they are relevant to this particular problem.
It all depends on what's inside the install log 🙂
I was having the exact same problem, and so when I went to reinstall, I instead chose to install utilities, then reinstalled to install program on computer. suddenly its working and that was the only change I made.
Hello @Anonymous!
Were you able to check your installation log to see where it's failing?
I have been trying to download the students version of maya 2015
i already disabled my antivirus the firewall im connected to an ethernet but this keeps showing up
I have also tried the in browser download and it shows up to the extract all screen but after that it says one file was not downloaded or im missing a file.
Same here.
First communication error as above, so I DLed the manager download package.
Came in fine, but then the Installation Failure splash as someone else here posted.
Some serious hooplah to install the big M, huh?
I have an OK system that runs Blender, Modo and LW just fine and never had any install issues.
Clean and updated Win7 64bit.
Wonder if this could be a bug in the 2015 installer?!
I am having a slightly different problem with my install of MAYA 2015...
Dowload through browser is OK but when I try and do the install with my key code and ser # the only option I have is a 30 day trial....
NOT the Student 3 Year install ???
This was on Mavericks 10.9.1
I managed to install 2014 Student 3 year with NO PROBLEM on same system but different OS (Mountain Lion) (Different boot partition)
BUT I would really like to get 2015 up and running on my Mavericks 10.9.1
Any thoughts or solutions ???
