I dont know what it is but the download speed goes from 1.5 mb/s to 60 b/s with an estimated completion of 5000+ days. Ive tried lowering th euac, firewall, turning off anti-virus.
Hi @Anonymous
It sounds like your firewall may not be completely disabled. Please, turn your firewall completely off and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
I solved it. I used the download version instead of the install version and it downloaded and then installed fine. but i never got the install version to work.
Once you've got the installer, back up a copy of it somewhere in case you need to install again. That applies to pretty much every program you install.
