I have just installed Maya 2015 64-bit Student Version on my computer.
I am running Windows 7 64-bit Professional.
Maya 2015 installs but Mental Ray failed to install.
I have also installed 3ds Max 2015 64-bit Student Version on this same computer.
I have attached to this post a zip file called "Maya_Install_Logs_8_11_14.rar"
(I am unable to create a .zip because the Maya2015_x64_Install.log is too large for a .zip i.e. 65mb and only compresses down to 5 mb)
It contains:
Maya2015Setup.log
MentalRayPlugIn2015_x64_Install.log
Can you help me resolve this so that Mental Ray runs on Maya 2015.
Here is a post of the Maya2015Setup.log
2014/8/11:02:47:57 mcp MCP1 === Setup started on MCP1 by mcp ===
2014/8/11:02:47:57 mcp MCP1 Path_Length: 143
2014/8/11:02:47:57 mcp MCP1 Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_dlm
2014/8/11:02:47:57 mcp MCP1 Launch
2014/8/11:02:47:57 mcp MCP1 CommandLine
2014/8/11:02:47:57 mcp MCP1 Current Directory C:\Users\mcp\AppData\Local\Temp\_AI6671.tmp
2014/8/11:02:48:02 mcp MCP1 === Setup ended ===
2014/8/11:02:47:58 mcp MCP1 === Setup started on MCP1 by mcp ===
2014/8/11:02:47:58 mcp MCP1 Path_Length: 143
2014/8/11:02:47:58 mcp MCP1 Current Directory C:\Users\mcp\AppData\Local\Temp\_AI6671.tmp
2014/8/11:02:47:58 mcp MCP1 Launch
2014/8/11:02:48:02 mcp MCP1 PageOpen LaunchDialog
2014/8/11:02:48:03 mcp MCP1 PageOpen LicenseDialog
2014/8/11:02:48:05 mcp MCP1 PageOpen ProductSelectionDialog2
2014/8/11:02:48:06 mcp MCP1 PageOpen LicenseDialog
2014/8/11:02:48:08 mcp MCP1 PageOpen LaunchDialog
2014/8/11:02:48:10 mcp MCP1 PageOpen LicenseDialog
2014/8/11:02:48:26 mcp MCP1 PageOpen ProductSelectionDialog2
2014/8/11:02:48:50 mcp MCP1 PageOpen FullProgressDialog
2014/8/11:02:48:50 mcp MCP1 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/11:02:50:05 mcp MCP1 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/11:02:50:05 mcp MCP1 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/11:02:51:12 mcp MCP1 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/11:02:51:12 mcp MCP1 Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/11:02:52:20 mcp MCP1 Install DirectX® Runtime Succeeded
2014/8/11:02:52:23 mcp MCP1 Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\mcp\AppData\Local\Temp\_AI6671.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2015_R1_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/11:03:02:35 mcp MCP1 Install Autodesk® Maya® 2015 Succeeded
2014/8/11:03:22:17 mcp MCP1 Install Autodesk® Maya® 2015 SP2 Succeeded
2014/8/11:03:22:17 mcp MCP1 Installing mental ray® renderer for Autodesk® Maya® 2015: TRANSFORMS="C:\Users\mcp\AppData\Local\Temp\_AI6671.tmp\x64\MentalRayPlugIn\MentalRayPlugIn2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2015_R1_dlm\" INSTALLDIR="C:\Program Files\Autodesk\mentalrayForMaya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/11:03:22:20 mcp MCP1 Install mental ray® renderer for Autodesk® Maya® 2015 Failed Failure is ignored, Result=1618
2014/8/11:03:22:20 mcp MCP1 Install mental ray® renderer for Autodesk® Maya® 2015 SP2 Succeeded
2014/8/11:03:22:22 mcp MCP1 PageOpen InstallCompleteDialog
2014/8/11:03:22:46 mcp MCP1 === Setup ended ===
Here is a post of the MentalRayPlugIn2015_x64_Install.log
=== Verbose logging started: 8/11/2014 3:22:17 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Users\mcp\AppData\Local\Temp\_AI6671.tmp\Setup.exe ===
MSI (c) (40:98) [03:22:17:812]: Resetting cached policy values
MSI (c) (40:98) [03:22:17:812]: Machine policy value 'Debug' is 0
MSI (c) (40:98) [03:22:17:812]: ******* RunEngine:
******* Product: C:\Autodesk\Autodesk_Maya_2015_R1_dlm\x64\MentalRayPlugIn\MentalRayPlugIn2015.msi
******* Action:
******* CommandLine: **********
MSI (c) (40:98) [03:22:17:812]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (40:98) [03:22:20:823]: Failed to grab execution mutex. System error 258.
MSI (c) (40:98) [03:22:20:823]: Cloaking enabled.
MSI (c) (40:98) [03:22:20:823]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (40:98) [03:22:20:823]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (40:98) [03:22:20:823]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (40:98) [03:22:20:823]: MainEngineThread is returning 1618
=== Verbose logging stopped: 8/11/2014 3:22:20 ===
MSI (s) (B4:70) [03:23:30:329]: User policy value 'DisableRollback' is 0
MSI (s) (B4:70) [03:23:30:329]: Machine policy value 'DisableRollback' is 0
MSI (s) (B4:70) [03:23:30:329]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (B4:70) [03:23:30:329]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (B4:70) [03:23:30:329]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (B4:70) [03:23:30:329]: Post-install cleanup: removing installer file 'C:\Windows\Installer\4345a7.msp'
MSI (s) (B4:70) [03:23:30:329]: Restoring environment variables
MSI (s) (B4:70) [03:23:30:345]: Lost connection to custom action server process. Attempting to regenerate.
MSI (s) (B4:70) [03:23:30:345]: Destroying RemoteAPI object.
MSI (s) (B4:AC) [03:23:30:345]: Custom Action Manager thread ending.
