Sorry if this has already been covered I dont have time to search around for previous issues I was just hoping I can post the crash issue I am having and someone might have an answer... We have had several workstation crashes that involved anything from scaling keyframes to moving character handles around in the scene and maya just dissappeared here are the back trace debug logs maybe someone has some insight into the issue... I'm hoping its an X11 or driver issue here's what I got:
this is just alt rotating around the persp. view:
Program received signal SIGSEGV, Segmentation fault.
0x00002aaac8319397 in TscaleKeyContext::doPress(Tevent const&) ()
from /usr/autodesk/maya2011-x64/lib/libAnimUISlice.so
(gdb) bt
#0 0x00002aaac8319397 in TscaleKeyContext::doPress(Tevent const&) ()
#1 0x00002aaaad8bcc77 in TtoolCallback::doIt(Tevent const&) ()
from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#2 0x00002aaaad871c7d in Taction::performAction(Tevent const&, char const*) ()
#3 0x00002aaaad9b4cec in Taction::qt_metacall(QMetaObject::Call, int, void**)
() from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#4 0x00002aaab4a1639f in QMetaObject::activate(QObject*, int, int, void**) ()
from /usr/autodesk/maya2011-x64/lib/libQtCore.so.4
#5 0x00002aaaad9bd952 in QmayaInteractivePort::pressed(Tevent const&) ()
#6 0x00002aaaad9e9c2e in QmayaInteractivePort::mousePressEvent(QMouseEvent*)
#7 0x00002aaab4f15782 in QWidget::event(QEvent*) ()
from /usr/autodesk/maya2011-x64/lib/libQtGui.so.4
#8 0x00002aaab4ec451e in QApplicationPrivate::notify_helper(QObject*, QEvent*)
() from /usr/autodesk/maya2011-x64/lib/libQtGui.so.4
#9 0x00002aaab4ec99fb in QApplication::notify(QObject*, QEvent*) ()
#10 0x00002aaaad875d76 in QmayaApplication::notify(QObject*, QEvent*) ()
#11 0x00002aaab4a016c3 in QCoreApplication::notifyInternal(QObject*, QEvent*)
---Type <return> to continue, or q <return> to quit---
() from /usr/autodesk/maya2011-x64/lib/libQtCore.so.4
#12 0x00002aaab4ec8da1 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&) ()
#13 0x00002aaab4f2cdfd in QETWidget::translateMouseEvent(_XEvent const*) ()
#14 0x00002aaab4f2b3a7 in QApplication::x11ProcessEvent(_XEvent*) ()
#15 0x00002aaab4f52855 in QEventDispatcherX11::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/autodesk/maya2011-x64/lib/libQtGui.so.4
#16 0x00002aaab4a00b55 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/autodesk/maya2011-x64/lib/libQtCore.so.4
#17 0x00002aaab4a00dbc in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/autodesk/maya2011-x64/lib/libQtCore.so.4
#18 0x00002aaab4a02b39 in QCoreApplication::exec() ()
#19 0x00002aaaad873285 in Tapplication::start() ()
#20 0x000000000040e662 in appmain() ()
#21 0x000000000041c6e1 in main ()
(gdb) Traceback (most recent call last):
Quit
File "/sl/shared/data/apps/python/mayalauncherformd.py", line 2030, in launchMaya
File "/prod/data/apps/python/ddmayad.py", line 78, in ?
subprocess.call ("/usr/autodesk/maya" + mayaVer + "/bin/maya -d gdb", shell=True)
File "/usr/lib64/python2.4/subprocess.py", line 419, in call
return Popen(*args, **kwargs).wait()
File "/usr/lib64/python2.4/subprocess.py", line 1027, in wait
pid, sts = os.waitpid(self.pid, 0)
KeyboardInterrupt
File "/prod/data/apps/python/ddmayad", line 8, in ?
subprocess.call ("mayalauncherd.py", shell=True)
KeyboardInterrupt
$ subprocess.call( cmdStr ,shell=True)
KeyboardInterrupt
this is scaling anim curves:
(gdb) bt
and another scale anim curves:
0x00002aaacc47a397 in TscaleKeyContext::doPress(Tevent const&) () from /usr/autodesk/maya2011-x64/lib/libAnimUISlice.so
(gdb) bt
#0 0x00002aaacc47a397 in TscaleKeyContext::doPress(Tevent const&) () from /usr/autodesk/maya2011-x64/lib/libAnimUISlice.so
#1 0x00002aaaad8bcc77 in TtoolCallback::doIt(Tevent const&) () from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#2 0x00002aaaad871c7d in Taction::performAction(Tevent const&, char const*) () from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#3 0x00002aaaad9b4cec in Taction::qt_metacall(QMetaObject::Call, int, void**) () from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#4 0x00002aaab4a1639f in QMetaObject::activate(QObject*, int, int, void**) () from /usr/autodesk/maya2011-x64/lib/libQtCore.so.4
#5 0x00002aaaad9bd952 in QmayaInteractivePort::pressed(Tevent const&) () from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#6 0x00002aaaad9e9c2e in QmayaInteractivePort::mousePressEvent(QMouseEvent*) () from /usr/autodesk/maya2011-x64/lib/libExtensionLayer.so
#7 0x00002aaab4f15782 in QWidget::event(QEvent*) () from /usr/autodesk/maya2011-x64/lib/libQtGui.so.4
#8 0x00002aaab4ec4
