I'm having a similar problem....When I try to run Maya, it shows the loading screen and it gets all the way to loading "Time Slider" and then this fatal error notification pops up and basically Maya crashes....I've tried literally everything on the internet that I can find to try and get this to go away, but nothing's worked!! The only other thing I saw was disabling "overlay" but I don't know what that is or where to find those settings..help please!
My computer info:
Windows Vista
Toshiba Satellite A215-S7425
Video Card: ATI Radeon x1200
- need any other info?
I have done all of the following with no luck:
1. Reinstalled Maya
2. Disabled triple buffering
3. De-selected "use application settings" on Anti-aliasing and anisotropic filtering; they are each set to 2X
4. Disabled Catalyst A.I.
ANY IDEAS????
Does it have anything to do with the fact that its the Trial version?
Here's the crash log....
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x16A68E40
Fault address: 16A68E40 in <ÏLv
0000:00000000 Logical offset (see .map file for location)
Registers:
EAX:0E12B87B
EBX:16AD4A80
ECX:16A8A000
EDX:00000004
ESI:15F09040
EDI:0144EA7C
CS:EIP:001B:16A68E40
SS:ESP:0023:0144EA2C EBP:16C0C2D0
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010246
Call stack:
(0) section:offset Address Frame
0000:00000000 0x16A68E40 0x00000000
(1) section:offset Address Frame
0001:000D70E2 0x13DB80E2 0x00000000
Module: C:\Windows\system32\atioglxx.dll (-exported-)
Decl: atiPPHSN
(2) section:offset Address Frame
0001:0008C2B5 0x13D6D2B5 0x00000000
Decl: DrvPresentBuffers
(3) section:offset Address Frame
0001:0008C165 0x13D6D165 0x00000000
Next frame pointer is missing - is /Oy turned on in this module?
//crash file = C:\Users\user\AppData\Local\Temp\MayaCra...
//version = 2008.11.13.0729
//cut = Thu 11/13/2008, 200811130729
//Memory usage:
// 812.035 Mb Free Memory
// 2048.000 Mb Free Swap
// 211.715 Mb Current
// 0.131 Mb arguments
// 29.375 Mb MEL
// 0.124 Mb Transforms
// 0.313 Mb Data Blocks
