Installation & Licensing
Message 1 of 14
15667 Views, 13 Replies
log4cplus ERROR
After installing Maya 2014, when it started the Output Window popped up right away spitting out the following errors:
log4cplus:ERROR No appenders could be found for logger (AdSyncNamespace).
log4cplus:ERROR Please initialize the log4cplus system properly.
So far Maya seems to be working normally but will this cause problems in the future? What exactly is causing these errors? Anybody know?
13 REPLIES 13
Message 2 of 14
warnold1
I would not expect the message to cause a problem for Maya
What other Autodesk products do you have installed ?
What entries do you have in the windows registry
HKLM/SOFTWARE/Autodesk/UPI
Wayne Arnold
Developer
Message 3 of 14
I have AutoCAD 2014, 3ds Max 2014, and Maya 2014 installed.
Contents of HKLM/SOFTWARE/Autodesk/UPI:
Message 4 of 14
warnold1
The 1st entry: bin/UPI/UPI.dll you can delete, it doesn't hurt but doesn't exist
For the others one by one modify the UPI.dll to UPI-hide.dll then start Maya see for which entry(s)
the messages don't appear
Return the entries to their original values
Wayne Arnold
Developer
Message 5 of 14
Deleted bin/UPI/UPI.dll entry.
I edited them as you said and started Maya up each time, every time the output console would pop up and throw the errors posted in the original post.
Message 6 of 14
warnold1
it may actually be the xml entry, the Key, not the Value
this xml file is used to find the UPI info for a product, which may attempt to load an executable/shared library.
Wayne Arnold
Developer
Message 7 of 14
DarrenP
autodesk 360 is what is causing this to show up in the output window
uninstalling it makes this go away
DarrenP
Message 8 of 14
Thank you, uninstalled 360 and everything is ok. 😃
Message 9 of 14
thanks for all
Message 10 of 14
how should i solve this problem
Message 11 of 14
in reply to: DarrenP
Uninstalling the AutoDesk 360 is making saving from AutoCAd 2014 very slow. a dwg with only 1 line in it takes suddenly 5-10 min to save to lokal C: drive. That was not expected. Any Thougt on this problem. Uninstalled AutoDesk 360 using msiexec.
Message 12 of 14
Awesome! it was causing a different to **** up... You're a lifesaver! 😄
Message 13 of 14
Is there any way of solving this problem without uninstalling AutoDesk 360?
Message 14 of 14
Hi. I'm having the same issue with log4cplus. Is there a way to remove this error without uninstalling Autodesk 360 ?
Administrator Productivity
