I have a student license and have used 3ds max 2014. Suddenly I could not start the program, it froze at "starting 3ds max".
I uninstalled everything and downloaded another version via the Virtual agent. I did this a few weeks ago without problem.
This time I could also download and install, but when finished I realised that I by mistake had installed the 2015 version. Maybe this is ok for student licenses, but when starting the program it says that I have purchased it! And that I have 30 days left to activate it.
How do I change license type back to student? And why did it become a purchased version instead of a student version?
Torun
Hi there!
Not to worry, you haven't made a purchase You just downloaded a trial, you can activate this trial by using your license information from your Education Community account to convert the trial into a student license.
I hope this helps! If you have any other questions or concerns please let us know. Thanks!
Thank you Jessica, but I cant activate using the serial number I received from start. It says that this code is not valid!
Torun
Hello again! I now tried to do the same thing as I tried in the 2014 version that got stuck at "starting 3ds max". I changed the driver selection to "Legacy OpenGL". And now this 2015 version stops at "Starting 3ds max".
The reason why I do this is that I want to use "2D pan and zoom" and I have searched a lot and the only solution I found was this option. I also need "Smooth and highlights" and to use that I understood it as I have to use either Lagacy OpneGL or Legacy Direct3D.
Hi @TorunBr,
If you're experiencing licensing issues, please contact our Registration and Activation department directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
If you have any other questions please let us know. Thanks!
