Ok...right off the bat here I will admit that I have a rather hefty command line render running while I'm trying to work and as such, the machine's running a bit chunky, so I'm sure I inadvertantly hit something by mistake, however this has happened a couple of times now and it's really getting on my nerves...
For some reason, in the middle of working (again I'm sure I hit something by mistake) my mouse buttons...or at least the left mouse button starts working backwards. Instead of being able to click on an object or handle/pivot, etc., instead when I left click, it's bringing up the mouse menus. If I hold down the shift key, then it works as normal. If I close the program and re-open it, then everything is fine again...at least until the next time I do it.
What did I do and how do I fix it? ARRGGGGG!!!!
Thanks!
