Hello, I'm having trouble installing the student 2015 version of Maya on my Windows 7 computer, this is the most recent installation log that I keep getting:
2014/10/10:22:48:43 Cara CARA-PC === Setup started on CARA-PC by Cara ===
2014/10/10:22:48:43 Cara CARA-PC Path_Length: 143
2014/10/10:22:48:43 Cara CARA-PC Current Directory C:\Users\Cara\AppData\Local\Temp\_AI4664.tmp
2014/10/10:22:48:43 Cara CARA-PC Launch
2014/10/10:22:48:45 Cara CARA-PC PageOpen LaunchDialog
2014/10/10:22:48:46 Cara CARA-PC PageOpen LicenseDialog
2014/10/10:22:48:48 Cara CARA-PC PageOpen ProductInfoDialog
2014/10/10:22:49:27 Cara CARA-PC PageOpen ProductSelectionDialog2
2014/10/10:22:49:44 Cara CARA-PC PageOpen FullProgressDialog
2014/10/10:22:49:44 Cara CARA-PC Installing : "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/10:22:50:05 Cara CARA-PC Install Succeeded
2014/10/10:22:50:05 Cara CARA-PC Installing : "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/10:22:50:27 Cara CARA-PC Install Succeeded
2014/10/10:22:50:27 Cara CARA-PC Installing : "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\" /q
2014/10/10:22:50:27 Cara CARA-PC Install Failed Failure is ignored, Result=5
2014/10/10:22:50:27 Cara CARA-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\Autodesk_Maya_2015_R1_dlm\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/10/10:22:50:38 Cara CARA-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2014/10/10:22:50:38 Cara CARA-PC Rollback Failed Installation aborted, Result=1619
I have tried downloading from the virtual agent as well as but I still cant install Maya.
Thanks 🙂
I solved the problem, all i had to do was uninstall 2008,2010 and 2012 Visual C++ Redistributable both (x64) and (x86), and then downloaded 4.5 network framework and then ran the installation of Maya.
Hope this helps anyone that might have the same problem as I did.
