2014/11/27:17:49:36 eric56379 Eric === Setup started on Eric by eric56379 ===
2014/11/27:17:49:36 eric56379 Eric Path_Length: 148
2014/11/27:17:49:36 eric56379 Eric Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/11/27:17:49:36 eric56379 Eric Launch
2014/11/27:17:49:36 eric56379 Eric CommandLine /url "
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1417132144264
2014/11/27:17:49:36 eric56379 Eric Current Directory C:\Users\ERIC56~1\AppData\Local\Temp\_AIC617.tmp
2014/11/27:17:50:53 eric56379 Eric === Setup ended ===
2014/11/27:17:49:40 eric56379 Eric === Setup started on Eric by eric56379 ===
2014/11/27:17:49:40 eric56379 Eric Path_Length: 148
2014/11/27:17:49:40 eric56379 Eric Current Directory C:\Users\ERIC56~1\AppData\Local\Temp\_AIC617.tmp
2014/11/27:17:49:40 eric56379 Eric Launch
2014/11/27:17:50:35 eric56379 Eric Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/11/27:17:50:52 eric56379 Eric Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/11/27:17:50:53 eric56379 Eric PageOpen LaunchDialog
2014/11/27:17:57:22 eric56379 Eric PageOpen LicenseDialog
2014/11/27:17:57:22 eric56379 Eric PageOpen ProductInfoDialog
2014/11/27:17:57:31 eric56379 Eric PageOpen ProductSelectionDialog2
2014/11/27:17:57:42 eric56379 Eric PageOpen FullProgressDialog
2014/11/27:17:57:43 eric56379 Eric Download Play VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:17:57:45 eric56379 Eric Download Complete VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:17:57:45 eric56379 Eric Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/27:17:57:48 eric56379 Eric Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=-2147024546
2014/11/27:17:57:48 eric56379 Eric Download Play VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:17:57:49 eric56379 Eric Download Complete VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:17:57:50 eric56379 Eric Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/27:17:57:51 eric56379 Eric Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=-2147024546
2014/11/27:17:57:51 eric56379 Eric Download Play DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/11/27:17:57:53 eric56379 Eric Download Complete DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/11/27:17:57:53 eric56379 Eric Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/27:17:58:04 eric56379 Eric Install DirectX® Runtime Succeeded
2014/11/27:17:58:04 eric56379 Eric Download Play CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/11/27:17:58:17 eric56379 Eric Download Complete CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/11/27:17:58:17 eric56379 Eric Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:17:59:17 eric56379 Eric Install Autodesk® Material Library 2015 Succeeded
2014/11/27:17:59:17 eric56379 Eric Download Play CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/11/27:17:59:37 eric56379 Eric Download Complete CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/11/27:17:59:37 eric56379 Eric Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:18:00:04 eric56379 Eric Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/11/27:18:00:09 eric56379 Eric Download Error Connection has expired. Please reconnect to site. CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-...2014/11/27:18:00:09 eric56379 Eric Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/11/27:18:00:37 eric56379 Eric Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/11/27:18:01:08 eric56379 Eric Rollback Autodesk® Material Library 2015 Succeeded
2014/11/27:18:01:08 eric56379 Eric Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/27:18:01:09 eric56379 Eric PageOpen InstallCompleteDialog
2014/11/27:18:01:30 eric56379 Eric === Setup ended ===
2014/11/27:18:43:11 eric56379 ERIC === Setup started on ERIC by eric56379 ===
2014/11/27:18:43:11 eric56379 ERIC Path_Length: 148
2014/11/27:18:43:11 eric56379 ERIC Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/11/27:18:43:11 eric56379 ERIC Launch
2014/11/27:18:43:11 eric56379 ERIC CommandLine /url "
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1417135314049
2014/11/27:18:43:11 eric56379 ERIC Current Directory C:\Users\ERIC56~1\AppData\Local\Temp\_AIE16C.tmp
2014/11/27:18:43:54 eric56379 ERIC === Setup ended ===
2014/11/27:18:43:14 eric56379 ERIC === Setup started on ERIC by eric56379 ===
2014/11/27:18:43:14 eric56379 ERIC Path_Length: 148
2014/11/27:18:43:14 eric56379 ERIC Current Directory C:\Users\ERIC56~1\AppData\Local\Temp\_AIE16C.tmp
2014/11/27:18:43:14 eric56379 ERIC Launch
2014/11/27:18:43:54 eric56379 ERIC Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/11/27:18:43:54 eric56379 ERIC PageOpen LaunchDialog
2014/11/27:18:44:00 eric56379 ERIC PageOpen LicenseDialog
2014/11/27:18:44:00 eric56379 ERIC PageOpen ProductInfoDialog
2014/11/27:18:44:05 eric56379 ERIC PageOpen ProductSelectionDialog2
2014/11/27:18:44:08 eric56379 ERIC PageOpen FullProgressDialog
2014/11/27:18:44:09 eric56379 ERIC Download Play VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:18:44:10 eric56379 ERIC Download Complete VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:18:44:10 eric56379 ERIC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ERIC56~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/27:18:44:25 eric56379 ERIC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/11/27:18:44:25 eric56379 ERIC Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:18:44:25 eric56379 ERIC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/11/27:18:44:30 eric56379 ERIC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/11/27:18:44:30 eric56379 ERIC Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/11/27:18:44:30 eric56379 ERIC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/11/27:18:44:31 eric56379 ERIC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/11/27:18:44:32 eric56379 ERIC Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/11/27:18:44:32 eric56379 ERIC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/27:18:44:39 eric56379 ERIC Install DirectX® Runtime Succeeded
2014/11/27:18:44:39 eric56379 ERIC Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/11/27:18:44:39 eric56379 ERIC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:18:45:19 eric56379 ERIC Install Autodesk® Material Library 2015 Succeeded
2014/11/27:18:45:20 eric56379 ERIC Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/11/27:18:45:20 eric56379 ERIC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:18:45:42 eric56379 ERIC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/11/27:18:45:43 eric56379 ERIC Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/11/27:18:48:57 eric56379 ERIC Download Complete CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/11/27:18:48:57 eric56379 ERIC Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:18:49:46 eric56379 ERIC Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/11/27:18:49:46 eric56379 ERIC Download Play ADAPPLICATIONMANAGER
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/ADAPPLICA...2014/11/27:18:50:02 eric56379 ERIC Download Complete ADAPPLICATIONMANAGER
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/ADAPPLICA...2014/11/27:18:50:02 eric56379 ERIC Installing Autodesk Application Manager: "C:\Autodesk\WI\Autodesk 3ds Max 2015\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/11/27:18:51:05 eric56379 ERIC Install Autodesk Application Manager Succeeded
2014/11/27:18:51:05 eric56379 ERIC Download Play MAX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/MAX.tar.l...2014/11/27:18:58:02 eric56379 ERIC Download Complete MAX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/MAX.tar.l...2014/11/27:18:58:05 eric56379 ERIC Installing Autodesk® 3ds Max 2015: TRANSFORMS="C:\Users\ERIC56~1\AppData\Local\Temp\_AIE16C.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:19:31:27 eric56379 ERIC Install Autodesk® 3ds Max 2015 Succeeded
2014/11/27:19:31:30 eric56379 ERIC Download Play PDATA
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/PDATA.tar...2014/11/27:19:33:54 eric56379 ERIC Download Complete PDATA
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/PDATA.tar...2014/11/27:19:34:02 eric56379 ERIC Installing Autodesk® Populate Data for 3ds Max 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/27:19:41:33 eric56379 ERIC Install Autodesk® Populate Data for 3ds Max 2015 Succeeded
2014/11/27:19:41:34 eric56379 ERIC Download Play SP1
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SP1.tar.l...2014/11/27:19:42:22 eric56379 ERIC Download Complete SP1
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SP1.tar.l...2014/11/27:19:42:22 eric56379 ERIC Installing Autodesk® 3ds Max 2015 SP1: "C:\Autodesk\WI\Autodesk 3ds Max 2015\x64\Patch\3dsMax2015_SP1.exe" /q
2014/11/27:20:02:18 eric56379 ERIC Install Autodesk® 3ds Max 2015 SP1 Succeeded
2014/11/27:20:02:28 eric56379 ERIC Download Play BACKBURNER
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/BACKBURNE...2014/11/27:20:03:38 eric56379 ERIC Download Error BACKBURNER <B>Connection has expired.</B>Please Install Now again from the Autodesk website.
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/BACKBURNE...2014/11/27:20:03:39 eric56379 ERIC Download Aborted BACKBURNER
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/BACKBURNE...2014/11/27:20:03:39 eric56379 ERIC Install Autodesk® Backburner 2015 Failed Download Failed, Installation aborted, Result=1603
2014/11/27:20:04:08 eric56379 ERIC Download Play DC
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DC_x86.ta...2014/11/27:20:04:32 eric56379 ERIC Download Error DC <B>Connection has expired.</B>Please Install Now again from the Autodesk website.
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DC_x86.ta...2014/11/27:20:04:32 eric56379 ERIC Download Aborted DC
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DC_x86.ta...2014/11/27:20:04:32 eric56379 ERIC Install Autodesk® DirectConnect 2015 Failed Download Failed, Installation aborted, Result=1603
2014/11/27:20:04:32 eric56379 ERIC Download Skipped DCSP
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SP1.tar.l...2014/11/27:20:04:32 eric56379 ERIC Install Autodesk® DirectConnect 2015 HF1 Succeeded
2014/11/27:20:04:37 eric56379 ERIC Download Play INVENTOR_ENGINE
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/INVENTOR_...2014/11/27:20:04:53 eric56379 ERIC Download Error INVENTOR_ENGINE <B>Connection has expired.</B>Please Install Now again from the Autodesk website.
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/INVENTOR_...2014/11/27:20:04:53 eric56379 ERIC Download Aborted INVENTOR_ENGINE
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/INVENTOR_...2014/11/27:20:04:53 eric56379 ERIC Install Autodesk® Inventor Server Engine For 3ds Max 2015 Failed Download Failed, Installation aborted, Result=1603
2014/11/27:20:04:54 eric56379 ERIC Rollback Autodesk® DirectConnect 2015 HF1 Failed Installation aborted, Result=1619
2014/11/27:20:16:04 eric56379 ERIC Rollback Autodesk® Populate Data for 3ds Max 2015 Succeeded
2014/11/27:20:23:45 eric56379 ERIC Download User Play INVENTOR_ENGINE
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/INVENTOR_...2014/11/27:20:25:44 eric56379 ERIC Download Complete INVENTOR_ENGINE
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/INVENTOR_...2014/11/27:21:02:05 eric56379 ERIC Rollback Autodesk® 3ds Max 2015 Succeeded
2014/11/27:21:02:05 eric56379 ERIC Rollback Autodesk Application Manager Failed Failure is ignored, Result=1619
2014/11/27:21:02:37 eric56379 ERIC Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/11/27:21:03:06 eric56379 ERIC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/11/27:21:04:09 eric56379 ERIC Rollback Autodesk® Material Library 2015 Succeeded
2014/11/27:21:04:09 eric56379 ERIC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/11/27:21:04:09 eric56379 ERIC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/11/27:21:04:09 eric56379 ERIC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/11/27:21:04:10 eric56379 ERIC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
