Installation & Licensing
217 Views, 1 Reply
Freezing problem
I am running maya 2013 student. Without my action a maya window with "The file being saved was created by a Student Version of Maya intended for personal learning only. If you save the file, this message will always appear whenever the file is opened." suddenly appears and then maya freezes. I haven't tried to save or save as, it just does it on it's own.
the first respnse was this: The error you are facing might caused of your system does not have a certified graphic card. Go through the link below and verify if your hardware is certified for Autodesk Applications.
 I’m running Radeon HD 6970M 2048 MB and it seems OK according to Autodesk.
I am now having the same problem: starting from perspective to 4 panel view to side view and back, maya show 4 blank panels, freezes and has unresponsive 'save' window open. Must be force quit. Attempted to send crash report but unsure if it’s working. progress bar still rolling after ten minutes
graphics card checked out OK.
Tags (3)
1 REPLY 1
n8skow
What operating system are you using?
What video card driver version?
Administrator Productivity
