currently being in the mirgration process from 2014 to 2015, I noticed a very anoying thing. I have a floating license, atm only used my local workstation (which the server is also runnging on). When I have Maya 2014 open and try to open Maya2015 in parallel, I got a licensing error. Each version alone runs fine.
The expected behaviour is fine on node-locked machines.
What can I do?
Cheers
Felix
Running different versions simultaneously will attempt to pull two licenses. If you were to run two of the same version, or multiple products of the same version from a suite license, only one license would be pulled.
