Hi everone! I'm trying install the plugin File3D (http://johanneskopf.de/publications/solid/, download link is at the right bottom of the page), but it does not work. I created a folder called 'File3D' in the plug-ins folder containing three folders called 'plug-ins', 'scripts' and 'icons' and put the files in those folders. But when I try to load the plug-in in the plug-in manager, Maya gives an error because it cannot 'dynamically load' the plugin. Does anyone know how to solve this? Thanks in advance
Thank you for the quick reply. Do you know any method to make the plug-in/code work anyways? Or do you know if we can still download Maya 8.5?
Thank you for the answer again. I tried to contact the support, but the message showed up in this forum again. Could you advice me on how to contact the support?
