I have been trying to download maya lots of times and everytime I do it everything fails. I want to how to download it properly.
Are you sure your PC tops the minimun requirements of the software? Did you download the student version from the official Autodesk site? If your downloading maya 2014-2015 for your computer which has only 32 bit OS, you need the 64 bit, you knew this? Sry I'm not an expert, but maybe this offers some clues, idkr.
I have tried both 2014 and 2015 then I tried the 32 bit 2013. I get the same result with all of them which is failing. I'm sure my PC reaches the Minimum requirements for the software for 2015.
It's a little too wide plane trying to guess, when considering "failing". So the program just doesn't start or? How does it fail.
When I download the software, I can get to the installation process. It tells me that there are 10 parts to install but when it gets to part 5, thats when it tells me that the installation is complete and some products failed to install. The four products that fail are Autodesk Maya 2015, Mental Ray Renderer for Autodesk Maya 2015, Autodesk DirectConnect 2015 and Autodesk Application Manager
In this case you would probably want to take a look at your installation log to look for a specific failure reference.
Location of the log files generated by the installation of an Autodesk product
Once obtained I'd suggest searching on the Autodesk Knowledge Network site for relevant solutions.
