Hello, to all who have came across this. I bought the physical copy a few years ago and I decided to use it today, 2010 version of 3DS Max and wanted to install it. I managed to get past the Serial Number. The one issue I happened to encounter in the midst of this was that it couldn't verify the product key. I am connected to the internet, so this shouldn't have been a problem. I went throught the installation process and it seemingly installed. After this, I decided to boot it up. After I installed Nvidia, I found it requesting for my activation code. To get the program to work, I tried to use the request code and I also looked on the box, but couldn't find the code. I decided to register on the Autodesk so it could walk me throught the steps, and it seemingly began to work until I got to the registration. The error I stumbled upon was that it couldn't verify my postal code. I live in canada so my postal code has 6 digits. (000 000)
I decided to post here to see if there's anywhere or anyway to get the needed activation code. Any help or suggestions would be much appreciated.
Hi @theogam161
For direct activation and licensing assistance, please contact our License Assistance team by clicking on this link and then following the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
