I am a student and have no experience with Maya at all. I'm very interested to learn it and I have desktop that come with
Intel Core 2 Duo 3.1 Mhz
4Gb of Ram
Windows 7 32 bit
1 TB Hard Drive
I didn't have graphic card yet but will this work for Maya 2013? If so, what kind graphic card do you recommended?
Solved by jeffrey.sin. Go to Solution.
Hi @Anonymous,
You can verify the comaptibility from this link to System requirements for Autodesk Maya 2013. Included there is the link to the Recommended Hardware wizard, which you can use to check which graphics card is recommended for the software you want.
I *highly* recommend changing to a 64-bit operating system and increasing to 8 GB (if not more) RAM.
