I have Maya 2015 installed on my C drive which is running out of space so whenever I install a program I make sure it saves all my files as default to my second drive E.
Is there a way to change the default Maya save location to my second drive. Maya has created a Maya folder on my C drive (in my documents folder) is there a way to move this to my E drive?
Dimitrios
Go to File / Project Window ,press "New"
set a Current Project name , maybe "My_default" or any you want
also set a location ,maybe "e:\maya" , click Accept
then go to File / set Project
set it to "e:\maya\My_default"
Now ,you can check the folder
It would create a lot of folders in it
assets, images, scripts, scenes, etc....done
This solution with change the default location. If you need make a new project look at solution above.
Continuing....
Go to Windows>>Settings/Preferences>>Preferences
Below the "Settings" tab >> go to "File/Projects" >>"Project Settings" will be at the top >> "Default Projects Directory"
