Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
Installation - Hardware - OS
Active Member
0 Kudos
Best Processor for Maya?
310 Views, 6 Replies
08-25-2010 06:40 AM
I want to buy a computer so I can use Maya and other software with a more perfect quality and performance. I want to know what processor can I use.
I have a motherboard with a LGA 775 socket.
I was thinking to buy a motherboard LGA 1156 with this: Intel Core i5-650 Clarkdale 3.2GHz LGA 1156 73W Dual-Core Desktop Processor BX80616I5650
or what other processor can I use for my motherboard.? or a Core 2 Quad ro Core 2 Duo will make it?
Thanx for the answers.
*Expert Elite* | Moderator
21 Kudos
Re: Best Processor for Maya?
08-25-2010 07:00 AM in reply to: supernenei
Assuming your referring to increasing your render speed, I'd get as fast a chip - with as many cores as possible.
I believe you can get a Core2Quad in a 775 LGA at 3GHz+
Active Member
0 Kudos
08-25-2010 07:13 AM in reply to: n8skow
Thanx. The problem is that when I am animating in Maya,it becomes to slow. I need something faster. I have an ATI Radeon HD 4550 nad 2 GB Ram, so what I need is a new processor, mine doesn't work.
So you think with these specifications a Core 2 Quad will work????
Another question:
What about changing to and AMD processor
Thanx
21 Kudos
08-25-2010 07:52 AM in reply to: supernenei
What becomes too slow?
The viewport?
Active Member
0 Kudos
08-25-2010 09:20 AM in reply to: n8skow
Yes, when I preview the aniamtion in the viewport it is to slow. To view a 100 frame animation, it lasts like 2 minutes. Too slow. Ive seen many tutorials doing animations and previewing them in the viewport, and they are normal, fast; mine not.
21 Kudos
08-27-2010 06:16 AM in reply to: supernenei
What your describing sounds more like an issue with the speed of your video card, (depending on what's actually happening in the scene.)
Active Contributor
0 Kudos
09-08-2010 07:39 AM in reply to: supernenei
I'd stay away from the 1156 series, I believe they're getting phased out. The LGA 1366 are getting ramped up in production, and you can get a decent i7-930 and motherboard deal right now. Plus, the 1366 series supports DDR3, and you have the upgrade ability down the line; whereas if you get an 1156, you'll probably end up upgrading in a year or two, and you won't have full ddr3 support.
