I'll bet Cy hasn't done this installation I had a question about. It's certainly a DVD problem, and not one related to my hardware. I'm not sure it's limited to Vista either, but it appears to be a 64 bit problem. I don't see these warnings with the 32 bit version.
The Installation documentation in a couple of places states this rather flakey information here:
Autodesk 3ds Max 2008 Installation Guide > Supplemental Tools and Utilities > Optional Tools > Optional Tools Installed from DVD 1 > Partners/Plug-Ins
Autodesk 3ds Max includes several partner plug-ins.
Warning You need to install Autodesk 3ds Max 2008 and also run it at least once before installing these plug-ins. This will improve the compatibility of the plug-ins with Autodesk 3ds Max 2008.
Warning Before installing the plug-ins (RPC™ Plug-Ins from ArchVision™, Inc., ...
Well since I never chose to install the RPC plugin with the installation I wondered what was up with that. The network installation by default installs the RPC plugin and there appears no way to deselect that option from the install.
Even downloading and installing a similarly dated but differing in file sizes RPC plugin from
http://www.archvision.com/ doesn't solve the problem.
The uninstall included with the RPC install only removes one file, and leave many others behind. The RPC install never appears to create any type of log file about what it's up to during installation.
So I just removed all the files in these 64 bit folders to get rid of the warning messages:
C:\Program Files\Autodesk\3ds Max 2008\mentalray\shaders_autoload\shaders
C:\Program Files\Autodesk\3ds Max 2008\plugins
It's definitely a bad DVD, but I'll bet everyone else received this via subscription too.
If archvision manages to provide a actual solution to this issue, I'll update this post.
