Hi guys! I got a new PC and tried to install 3Dsmax 2015 student version but I keep getting this weird error... (Obviously I have network or else you wont see this)
Thanks Anyway, Jonathan
Screenshot:
Solved by jessica.t. Go to Solution.
Hi @jprat and welcome to the Autodesk Community!
Try disabling your firewall / antivirus software and installing again. If that doesn't help, log into into your computer as the administrator and disable your UAC.
Let me know if that helps and if you need further assistance. Thanks!
This is very frustrating.
1. Why have a message that says that it needs internet connection when that is obviously not the problem?
I have internet connection and already installed several programs)
2. I have disabled firewall and set UAC to disable and it still fails to install with the same non informative message.
Last line is
Rollback Microsoft Visual C++2012 Redistributable (x86) failure is ignored, Result=1619
But hey I have only worked with this software since r1.2 so what do I know. Blame it on MS.
Yes some help would be awesome.
Try downloading from here
http://knowledge.autodesk.com/topics/account-management/software-downloads/download-methods/virtual-...
Please accept as a solution if this fully resolves the issue
DarrenP
