I just got the student version of 3ds max 2015 on my new laptop, and when I open it all the fonts and toobars are too small to even read. I am new to 3ds max and have tried loading the default UI setting but nothing changed. Also, my command panel is missing. I right-clicked on the main toolbar and checked the command panel off and on and still nothing appears. Any help would be great!
I have the same problem and the command panel is highlighted and checked
This issue has not been covered.
Almost all posts I've read through have to do with the Command Panel GOING missing at some point after installation. THIS issue has to do with the very first installation and booting of 3DS Max. The software boots up for the first time, and right away you notice that the Command Panel is non-existent. You try right-clicking to make sure that it is checked, and it is. There are many suggestions to try re-loading the Default UI settings, but as noted above, that doesn’t work either. This is also not an issue that has to do with dual screens. Can someone PLEASE help? This is a very frustrating issue, especially for someone very new to 3DS Max. The small font/icon issue seems to go hand and hand with the missing Command Panel, as I also have extremely small fonts that are almost impossible to read.
I have a brand new “Lenovo Y50 4K Ultra HD Signature Edition Gaming Laptop” Laptop purchased at a Windows store. Here are the specs;
Thank you for your time.
I have the same problem. Tiny fonts and missing command panel even if I have checked the box and tried loading UI scheme. Did you figure out a solution to your problem? Also new to 3Ds max..
i'm having the same problem of the size of to command panel and I still cannot find any solution.
I have also visited the above link which you have sent.
but still the problem is unsolved.
please help me solve my problem.
