I just got this program and I've been trying to install it for 3 hours. It constantly fails. At first it wouldn't install from the Web, so I downloaded the file and tried to install it.
It installs for 20 minuets and then tries to tell me that I'm out of disk space, when I have 615GB left on the drive that I'm installing on. Then it tries to reverse the entire installation process and I have t wait another 20 minuets for it to "uninstall".
I included a screen shot. I can't believe that this will take over 615GB to install.
You have multiple hard drives, correct? Its looking like your system drive (C: 120 GB, 711 MB free, 872 MB required) has insufficient space. Before you ask: no, you can't install the program on your data/non-system drive, like other programs critical components must be on the system drive.
There are several network drives. I told it to install on the D drive. I'm not sure what happened but I restarted the installation the fourth time, and I selected the D:\3ds15\ as the installation folder and it finally installed.
The progam loaded up so I am going to try using it and see what happens.
Thanks for responding.
