Can I use Insight 2020 version in Revit 2022? need guidance, please help.
Solved by sherryglopez. Go to Solution.
I downloaded the 2020 Insight plug in and it did not work with the 2022 Revit version. A dialog box said it needed the 2020 version. My suggestion is to download the 2020 version as well.
Yes, you can. Just update your Revit and install the add-in from Autodesk Desktop App.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Hi, could you say the exact location in analyze tab ? Because I do not see the solar option
Thank you
