Hello
I have a question about Miscellaneous equipment using Revit Energy Analysis. I use Export category: Spaces and Building type: Retail, area: 1500 m2.
In Results and compare, I always get the same results for Misc Equipment = 2760 kWh (facility 12/5) or 3328 kWh (facility default), but I want 0 kWh for Misc equipment. I also set lighting load density and power load density to 0 W/m2 and all schedules are Off - 24 hours.
Could you please help me!
Cheers, Martin
This looks like a continuation of http://forums.autodesk.com/t5/insight-360-general-discussion/energy-analysis-revit-results/td-p/5817...
It appears that Dennis responded to your questions in the above, but without a files it hard for us to know what's going on. Can you attach a sample file and your steps to re-create the results. Also, what are your expectations, what do you think Revit should be giving you for results?
Thanks for posting.
Also see mstein7484 posts in http://forums.autodesk.com/t5/energy-analysis/miscellaneous-equipment-help/m-p/5928580/highlight/tru...
