InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Zoom to model?
5 REPLIES 5
jmrhyne
8775 Views, 5 Replies
Zoom to model?
I am brand new to Infraworks 360 and am having a terrible time getting started.
I brought in a Civil 3D model and that worked great.  Then, I decided to bring in a second C3D model (surface).....I have no idea where the model was placed. I zoomed way out to try and find my second model, now I can't find either of them.
How would I go about finding a small piece of land that I inserted on the globe?  Isn't there any "zoom to model" type button?
Thanks.
5 REPLIES 5
BrianHailey
in reply to: jmrhyne
You can click the home icon on the view cube and that will, in essence, zoom extents. You can also choose something in the model explorer and then zoom to the object selected.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
jmrhyne
in reply to: BrianHailey
Thanks, Brian. I thought I had tried the home button previously, with no success, but it appears this is the answer!
gbattinPH5TG
Why does it not even zoom to the model?
I am in the same zone as brian (Denver) but it doesn't zoom to the extents or model...
Why must I use this crap without it having to read a manual?
I just want it to zoom to my stuff!!!
boyd_johnson
Clicking the Home button is not the same as "Zoom Extents"  "Home" is just a "saved view."  It is quite possible to have "elements" way outside of what you see when you click the Home buttom.
I'm still looking for the answer to"  "How do you zoom extents in Infraworks?"
I had the same issue and came here for an answer. Obviously couldn't find it so played around and found the button I was looking for - I am assuming it's the same one you were looking for.
After clicking on the model you want to zoom to in your Data Sources panel, right-click, select "Select Features" then go to the select button (the one with a standard arrow just above your selected features properties panel). A dropdown should appear with the first option being "Zoom to Selected".
Rail Community
