InfraWorks General Discussion
New Member
slezacek
Message 1 of 8 (1,122 Views)
WMS Server
1122 Views, 7 Replies
04-16-2012 12:50 AM
Hello, I would like  conect to WMS from IM. Is it possible ?
Thank you. Filip
Employee
konstantin.baumann
Message 2 of 8 (1,120 Views)
Re: WMS Server
04-16-2012 01:46 AM in reply to: slezacek
Since we are using GDAL (1.8.x) for raster data input, this page might help you to setup the required XML description file for describing the corresponding WMS server: http://www.gdal.org/frmt_wms.html
If you need more support you could also post some more infos about the WMS you want to access and we can try to figure out, which paramaters to set in the required GDAL-XML file...
New Member
slezacek
Message 3 of 8 (1,107 Views)
Re: WMS Server
04-17-2012 02:28 AM in reply to: konstantin.baumann
Hello Konstantin,
thank you for your answer. Can you help me with this url ? : http://wms.cuzk.cz/wms.asp
Thank you. Filip
Employee
konstantin.baumann
Message 4 of 8 (1,100 Views)
Re: WMS Server
04-17-2012 05:41 AM in reply to: slezacek
Since the call to:
http://services.cuzk.cz/wms/wms.asp?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
does not return a XML specification of this service, I don't know how to get to the required elements for the GDAL XML file.
This sample request demonstrates an expected and usable XML server reply:
http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
Maybe you can check for the bbox of the service in LL84 and also figure out the ground pixel resolution of the highest resolution layer?
edward.winter
Message 5 of 8 (609 Views)
Re: WMS Server
03-31-2014 03:05 AM in reply to: slezacek
Hi, I want to connect with below wms service. Can you check if this service respond well? And if so, how do I connect to it within InfraWorks R2 (or 360 R4)? http://geodata1.nationaalgeoregister.nl/luchtfoto/wms?request=GetCapabilities Thanks, Kind regards, Edward Winter
John.DeLeeuw
Message 6 of 8 (604 Views)
Re: WMS Server
03-31-2014 03:18 AM in reply to: edward.winter
Hi Edward, have you read through this post?
John
edward.winter
Message 7 of 8 (599 Views)
Re: WMS Server
03-31-2014 03:24 AM in reply to: John.DeLeeuw
Hi John,
Thanks for the quick respond.
I just saw your post right in another Google search.
Going to look in to it.
Just gave that post a kudo.
Edward
edward.winter
Message 8 of 8 (544 Views)
Re: WMS Server
04-17-2014 12:15 AM in reply to: John.DeLeeuw
John,
Initially I could not solve it by your example in the first place. Getting errors all the time.
So I started to research and explore the GDAL WMS from scratch by my self. And that's always the best thing you should do by the way.
I've started with to get an image from a Web Map Service url. That's where I figured out the image scaling.
Then I tried to create a World File to associate with. Ended successfully.
And by going that way and using below description of the GDAL WMS I finally figured out how I should built the GDAL XML.
What also helped me to solve this, is that I could use InfraWorks beta debug screen to detect the errors.
Looking back to your example, your explanation is correct, but misses to my opinion some important details.
Scaling the image is the most important one.
I'll write about it in a blog soon.
Edward
http://C3Dpeanuts.wordpress.com
