We have installed Infraworks 2015 on a users workstation and they're trying to add a DWG to the Model however each time they add it Infraworks says it need Navisworks Simulate or Manage 2015 installing alongside Infraworks.
Why is this? Can somone explain please...
Duncan
Solved by DarrenP. Go to Solution.
This changed in Infraworks 2014 R2 for whatever reason
you have 2 options for data import use the Cloud or use the local import which requires Navisworks 2015 to be installed which is being used to for the file conversion
DarrenP
But you can't use the Cloud option with Infraworks 2015 unless you bought the Infraworks Companion i guess?
Beats me why the local import couldn't just have the part of Navisworks that it needs to do the job for the Import.
Duncan
Duncan
yes this option is only in Infraworks 360
DarrenP
Ok, so we installed Navisworks Simulate 2015 with Infraworks 2015 but when the user tried to import a DWG to Infraworks, Infraworks reported that it was unable to import plugins. Please run as administrator.
When you clicked on show details, it said Navisworks Simulate Plugins failed to load.
Once ran as administrator, the issue seems to have gone. Does this mean the product has to be ran first by a Local Administrator as we cannot be making everyone Local Administrators.
I believe the issue is realted to this... does anyone know the three files it copies and whether you can supply these with installs of Navis Manage and Simulate to get round the issue of users having to run as administrator.
Duncan
