There is a free GIS website in US, however, in UK where can we find free aerial image and free existing roads data? Any recommendations?
Solved by neilyj666. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks neilyj, so how do you work on infraworks? Do you do it without an aerial image or use a paid one?
or even if you don't have GE pro.....but I couldn't possible suggest that method...:)
I've found that it's far better to buy the real thing as the quality is usually pretty good e.g. most of UK is available at 25cm per pixel resolution with other areas at 12.5cm (in my experience 25cm produces satisfactory results)
