InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
water areas within designed dams and channels
4 REPLIES 4
BruceAdams
767 Views, 4 Replies
I'm doing some flood analysis of a 100 yr flood zone. I need the water body object shown to be tranparent, so the image file can be seen showing the properties visable that flood.
4 REPLIES 4
Varhun.Prasad
in reply to: BruceAdams
Hi Mate,
You need to adjust the material settings in order to do this. Bascially you have to find the "color" component and set the "alpha" to a low number. You'll have to save this as a new material.
You could also show it is a coverage area instead of a water area. That way you can set the alpha value of the color straight from the style properties instead of having to create a new material.
Use the "manage surface layers" to set the different coverage layers in order of preference and you should have the result you're after.
Varhun
BruceAdams
Thanks for the tips.  Worked like a champ.
tcorey
Bruce, which did you do, create a new material for the water style or use a land cover style?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Eric_Chappell
Bruce,
Since you're doing this type of work, consider checking out Project Boulder: https://beta.autodesk.com/callout/?callid=%7BABADE776-9718-43AD-9C88-47A011D71CBA%7D
Eric Chappell
Rail Community
