Hi Again!
Is there a way to incorporate the Tooltip in the AVI you create using Show motion? Meaning while creating scenes, the tooltip will also be shown in the video?
Or is there a way to label object you create/import in AIM? then later show it in the video you create using SHow Motion?
Thanks!
.....looking for a solution as well.
If you are need a method for placing text, you may try this.
So far i could just put in the name as 3D-object with geometric coordinates.
Use explode text in express tools to convert text to polyline. Then make 3dsolid/surface of them.
Manually place them at the desired place.
Wish there is a easier way in AIM.
