Is it possible to use map servers like Open Street Map in AIM?
Currently Infrastructure modeller does not directly read the PBF or XML formats provided by open street map. However as suggested here you could process the data provided into a format that AIM can use.
http://planet.openstreetmap.org/
The model builder service can be leveraged to bring OSM data into a model, there is not a direct import available in the product. If there is a specific mapping service you are interested in connecting to it is possible that a connection could be established via the data connection interface. There are numerous connections available from the OSEGO and OGR libraries, along with WFS connections. The OSM provider is not currently in the list.
Now that we are in 2020 is there a way to directly import OpenStreetMap data into Infraworks? It is my understanding that some of the initial model-builder info comes from OpenStreetMap, but there is much more data that I would like to tap if at all possible. Has someone figured out a way to do this? Or can Autodesk weigh in on this topic? Thanks in advance for your everyone weighing in on this!
Have you tried "Connector for ArcGIS" and access public data from ESRI Living Atlas and other public data?
Hi @sduffin ,
it's not possible to connect to OpenStreetMap data directly and just import data sources.
But as far as I know, you can download OSM data, for example as shape files and separated by topic/feature. It's then possible to import this data source to InfraWorks.
Karsten.
@Karsten.Saenger @jeffmorris @ramesh_sridharan
There sure is a huge amount of data on OSM.
I use a local sqlite database of relevant OSM layers which is automatically updated weekly.
I've found that setting up style rules for styling based on OSM attribution can be pretty handy.
I normally just connect to the local database in Infraworks, and it lets me pick the desired layers. It's slightly preferable to SHP, and keeps things all in one place, and you can clip to model extent as required - all smoothly inside Infraworks.
Thanks for your reply! Can you provide more details on how you establish a local sql database of OSM layers? Is this a software download? Do you manually download from OSM? Also, once your database is established, can you share more details on how you import that data to Infraworks?
Thanks for your further insight!
Ramesh - yes we love the GIS connector, and we do have an ArcGIS Enterprise account, but sometimes OpenStreetMaps has the data I need. I am still exploring with our GIS folks all that is available through our account. I guess I am looking at flexibility of accessing many datasources to quickly get the data I need. Thanks for your reply!
Hi @sduffin ,
my idea was to download OSM data sources directly. There are different sites that offer these data for download, for example: http://download.geofabrik.de/
Once you have the shape files you could add these with according feature types in InfraWorks.
Does this make sense?
Karsten.
OSM has an API for data reading - so my colleague set up a process that spatially queries this API for data within my country. This could be implemented a number of ways. We use FME server, but I believe there are python wrappers for the API too. Definitely ask your GIS team, they may be able to assist.
These automated queries are formatted as appropriate for sqlite and saved as a single file on our network, which I can use as a data source directly in Infraworks.
The user interaction is the same as using a multi feature class SDF (for good reasons!).
