I'm a complete newbie to Infraworks and recently had Infraworks 360 pro w/ Roads installed.
When I create a Road using "Create Roads" option I'm unable to split the road.
It's likely a lack of understanding on my part but in the videos I've seen (and am trying to replicate their steps)
there are Gizmos immediately available when completing sketch road.
I've tried to split the road using the Create/Edit Features>Edit Existing Features but haven't figured out how to select it.
I have yet to see a Gizmo and I'm at a loss as to why?
Solved by ToddRogers-WPM. Go to Solution.
Hi Todd, thanks for the reply.
The "Create Roads" option was used and prior to posting I saw This thread which lead me to believe this was the method that would allow a split road.
Even if it were a "Design Road" shouldn't Gizmos appear when completing draw road or when selecting road?
Do you have any idea why I'm not seeing any Gizmos?
You won't get the usual gizmos, you will have some square grips and that's about it. I think they designed it to where you need to use the profile view to edit the road.
Ok, so how would I go about creating one that can be split (add a bridge) on?
Use the very first icon, Create Roads [Roads]. Don't use anything that has the word Design.
I was only using the Create Road option all along but it must have been something with the file I was using.
I was trying to add a road and then split it using the OOTB San Francisco model and for whatever reason a
split doesn't seem possible in that file.
I grabbed another file and it seems to work just fine.
