The first video when you open infraworks tells me about a training pdf that tells you how to get data and runs you through an excercise and talks about solid modeling. Does anybody have a download link?
TIA
Infraworks 2014
Solved by tcorey. Go to Solution.
http://docs.autodesk.com/ICD/2014/ENU/Training%20Guide/Autodesk%20Infraworks%20Training%20Guide.pdf
If you are interstested, I did a presentation for AU 2012 virtual that will walk you through the whole process of getting started, all the way through created a video for presentation.
http://au.autodesk.com/?nd=class&session_id=10707
I was going through your presentation on the link you provided but module 2 is actually 3, module 3 is 4 and 4 is 5. Did I miss something in the first module?
No problem! I thought maybe that was the case! Thanks! Ill keep watching!
