I'm having difficulty with this.
I created a spline then converted to polyline and added Civil Points at the vertices, added the EG surface level to the points and raised them 15m. I then sdf'd the data and when I played it in IW, none of my terrain was visible but the flight path was playing as the view cube was moving.
Where am i going wrong with this?
Neil
Perhaps play around with the transition settings and make sure the timing is set to "Keep Speed".
Haven't used the path from points option much personally.
