InfraWorks General Discussion
Active Contributor
chris.mckinzie
Message 1 of 5 (1,217 Views)
Terrain Data
1217 Views, 4 Replies
10-10-2012 11:51 AM
I am brand new to Infrastructure Modeler and I was just curious what the best source for information such as terrain data that can be imported into AIM.
BrianHailey
Message 2 of 5 (1,209 Views)
Re: Terrain Data
10-10-2012 03:21 PM in reply to: chris.mckinzie
Active Contributor
chris.mckinzie
Message 3 of 5 (1,196 Views)
Re: Terrain Data
10-11-2012 02:57 PM in reply to: BrianHailey
Awesome!  Thanks!
One other question.  When you are setting up a new model and the dialog box opens up where you can define the city extents...  How do you go about doing that?  I assume it's asking for the GPS points for the corners of the area you want, but I'm not sure exactly what order to put those in as and what format to use.
Employee
heiko.meyerdirks
Message 4 of 5 (1,185 Views)
Re: Terrain Data
10-12-2012 02:17 AM in reply to: chris.mckinzie
You can also change and interactively define the city extend afterwards once you have loaded data. Manage -> Model Settings -> Extent
The option in the new dialog is for users dealing with huge datasets but just needing a small area so they do not have to create a huge model first.
Heiko
Heiko Meyerdirks
Engineering Manager
Autodesk IPG ICP InfraWorks
Active Contributor
chris.mckinzie
Message 5 of 5 (1,182 Views)
Re: Terrain Data
10-12-2012 05:08 AM in reply to: heiko.meyerdirks
When I import shape files all I get is a brown image in the drawing with no detail.  I've tried several different shape files from several different sites and keep getting the same thing.  Any ideas?
