Hi..
I'have terrain and raster at same position. When I opened raster only or terrain ony there's no problem at all. But The visual appear not properly when I load both, raster and terrain.. As attached..
Does anyone know what the problem is?
Kindly need your advice all..
NRDamayanti
does that always appear like that or is it depending from the direction of sight/the camera-height/...?
If it depends on images you might try to change the format of the image, e.g. if you have uncompressed TIFF's try to convert them to LZW-compressed ones or to JPG's (be careful in that case with your georeference world file: TFW has to be changed to JGW).
Another option is to change the 3D graphics settings within your IW, play with these settings:
HTH, - alfred -
Hi there this is pretty bad. Can you provide the two files so we can have a deeper look.
Thx
Andreas
I can honestly say that is a graphics card problem (not sure if its a driver issue or hardware though).
I have two machines, exact same specs but one has a Quadro k1000 1GB and the other is a Quadro k2000 2GB. On the machine with the 1GB card I had this exact problem. It would drape fine but once you start moving the model around this happens. The same model on the 2GB machine works a charm.
Try that same model on another, better spec'd machine, and see what happens.
Varhun
