I'm trying to create a fly over presentation. Im' not able to get a smooth transition from one key frame to the next. I started with "Add Camera Path Animation". I have tried the 3 different options for interpolation from one frame to the next. But it doesn't seem to change the end result. I also tried all the different zoom and orbits. but I am just looking for a smooth fly over from frame to frame. Any suggestions??
Julie Turner-Mitchell
Solved by ToddRogers-WPM. Go to Solution.
I think I might know what you're doing wrong. First, you will need to create a camera path.
Once you have created the camera path, pan and zoom to the next "shot". Then click to add a Keyframe...
Then do the same procedure. You keep adding keyframes, not sequences (camera paths).
Thanks for your instruction. Do you know of anywhere there is detailed instructions on storyboards and what the difference is between all the animation options??? I have figured out the geneal info, but would love to make a really cool video that doesn't look like an amateur did it. Thanks in advance!!
Julie
