InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Sketchup and Ambient Occlusion
8 REPLIES 8
Message 1 of 9
-HFenby-Taylor-
1532 Views, 8 Replies
While I'm asking questions, does anyone else have problems with ambient occlusion and external 3D models. In this case Sketchup model, also attempted converted to .dae
ambient occlusion corruption
8 REPLIES 8
Message 2 of 9
Move the .dae file from the models folder to the images folder.
Todd Rogers
Message 3 of 9
Colour1
in reply to: ToddRogers-WPM
huh?
do you mean in the .dae source folder? I don't have any textures applied to the model, so there isn't one.
Um, trying to work out what you mean, would you mind breaking it down a bit for me? Cheers.
Message 4 of 9
ToddRogers-WPM
in reply to: Colour1
If there are no textures, what is the issue with the ambient occlusion?
Todd Rogers
Message 5 of 9
that is indeed the question the question Man Indifferent Smiley Wink
This happens with all my sketchup models.
Below: With Ambient Occlusion
Below: Without Ambient Occlusion
Message 6 of 9
Do you have show backfaces on? You can toggle this on in the options.
Todd Rogers
Message 7 of 9
Well I've 'solved' the problem. Changed Ambient Occlusion Quality to Low and it resolved itself.
PERFECT! Ambient Occlussion Quality - Low. Showing Backfaces - False
Message 8 of 9
in reply to: -HFenby-Taylor-
I have the same problem with faces in High ambient occlusion. Problem even exist in Fremont model from Autodesk when I turn on High Ambient Occlusion. It will be great if someone have idea how to solve this problem, or it is a bug in software, since that problem persist from version 2014. Otherwise, I don't see need for High AO as option., since it is unusable for now.
Message 9 of 9
lippola
Hi there,
could it be that the model has faces which are doubled and close to each other so that AO volumes get "confused" when choosing one or the other face?
Andreas
Rail Community
