InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
SFF Files
7 REPLIES 7
Message 1 of 8
istvan_voiculescu
1807 Views, 7 Replies
SFF Files
Is there any way to edit those stock sff files? Any apps that manage and create them?
ISTVAN “ISHKA” VOICULESCU
CAD/IT Systems Admin Sr.
BIM / CADD MANAGER
CITY OF AUSTIN, PUBLIC WORKS DEPARTMENT
ENGINEERING SERVICES DIVISION
7 REPLIES 7
Message 2 of 8
Did you ever find a way to edit the sff files?
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 3 of 8
tony1978
in reply to: C3D_TomR
It's my understanding that you can make a few modifications to a SFF file with the Fighter Factory software which you can download for free at several different sites online. Never really tried this though so I cant guarantee that it will work.  What are you trying to achieve?
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
Message 4 of 8
C3D_TomR
in reply to: tony1978
For now I just want to copy the existing InfraWorks blue POI sff file to create different color POI markers.
Tom Richardson
Twitter | LinkedIn
Message 5 of 8
If you export only the desired SFF asset out of InfraWorks you can import it into something like Max to make your adjustments. Then reimport it into InfraWorks. This will also work for creating new textures for things like POI's.
Jason Delaney
3D Content Creation Intern - InfraWorks 360
Message 6 of 8
Jason also wrote a recent InfraTip about how to edit stock .sffs in order to change the face of street signs. You can read that here:
http://forums.autodesk.com/t5/infraworks-360-infratips/how-to-edit-stock-sff-3d-models-pois-trees-et...
Principal Specialist, Infrastructure
Tags (1)
Message 7 of 8
I've tried mulitple times to get that to work and it never has. I think it's because my model is a mile high and I'm in imperial units. Even after creating a surface at elevation 0, placing a sign, exporting it out, changing the image, and then importing it back in, the new sign is gigantic! I'm thinking it might be a unit issue from InfraWorks to Max and back to InfraWorks again.
If I get a chance, I'll change everything back to metric and try again.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 8
jdelaney4
in reply to: BrianHailey
When exporting from Max as an FBX be sure to set the correct units in the export window. If you leave it as automatic it will change the units from your default messing it up when you import it in the style Palette.
Rail Community
