Is there a way to display the road alignment station labels in Infraworks? I'm only able to see the stationing labels in profile view. Also, when I exported the IMX file from Infraworks and imported it into Civil3D, all the Stations were off. One alignment shows negative stations. Would really appreciate it if someone could help.
Thanks!
The only way I have found to do this is to turn the station labels into 3d models.
Export your model (be sure there's a corridor) to Civil View.
Open 3DS Max Design and import the vsp3d file you exported.
Open Civil View Explorer. Go to the Tools tab.
Run the Station Text Placement tool.
Select the resultant station labels and then export selected to 3Ds.
Import the 3ds files into Infraworks as 3d models. Voila, stationing!
@tcorey wrote:The only way I have found to do this is to turn the station labels into 3d models.
This might be a long shot but are you still around, tcorey? I am trying to do this exact thing right now and after generating the text in 3ds max, and exporting, I cannot get it to import into infraworks. I've tried exporting as a 3d studio model, FBX, OBJ.... everytime it just doesn't export anything. When I open the model to preview it in 3D viewier it is blank and when i try to import it into infraworks it also doesn't work.... oddly enough if I export the entire scene (surface + everything) it seems to work but I do not want all of that... I only want the text as a 3d object.
@andrewofabley wrote:If you are prepared to share your MAX file, I'm happy to take a look too.
Awesome please see attached.
I had to remove the surface as it is a 10km corridor so the file was enormous. When I select all of the text mesh in the file, then export to 3d studio file and import into Infraworks I get a 3d model that looks like the attached image.
Any help would be greatly appreciated.
Ended up figuring it out, but is there a way to bring in the 3d model and retain it's georeferencing? At the moment I am having to interactively place it... which is fine as it's just for a visual at the moment but would be good to know if it's possible
I'm assuming that you noticed that your units were set to inches and corrected that, and perhaps you tweaked your export settings? It's working fine at my end once that's sorted.
In order to retain your georeferencing, you will need to know what your export / import offsets are. 3DS Max likes your content close to the origin, so it will often offer you an offset when you import it.
Simply offset it back by the same amount when you import this to Infraworks, and it should behave itself.
Good luck.
You are correct on the units.
Also thank you. After entering the offset values that 3ds prompted me with when imported the Civil 3D export the text lined up perfectly!
@andrewofabley wrote:I'm assuming that you noticed that your units were set to inches and corrected that, and perhaps you tweaked your export settings? It's working fine at my end once that's sorted.
Good luck.
