InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Revit Model not showing up
2 REPLIES 2
afinnerty
2081 Views, 2 Replies
I used model builder to get the MASS GIS data loaded and then tried to import a .RVT model. The model is nowhere to be found although it says "Imported." Where do I find and move my models?! HELP!
2 REPLIES 2
Willy_Campbell
in reply to: afinnerty
Hi Amanda,
Did you try to use Interactive Placement for the RVT model when configuring? It appears to be coming in to the model, but not geolocated. The Infraworks Model Builder data is real-world, but typically Revit uses a local [to the model] coordinate system. Even if you assign the correct CS to your RVT file, it will not import it into the correct location.
Willy Campbell
afinnerty
in reply to: Willy_Campbell
Thank you!!
Rail Community
