I used model builder to get the MASS GIS data loaded and then tried to import a .RVT model. The model is nowhere to be found although it says "Imported." Where do I find and move my models?! HELP!
Solved by Willy_Campbell. Go to Solution.
Hi Amanda,
Did you try to use Interactive Placement for the RVT model when configuring? It appears to be coming in to the model, but not geolocated. The Infraworks Model Builder data is real-world, but typically Revit uses a local [to the model] coordinate system. Even if you assign the correct CS to your RVT file, it will not import it into the correct location.
