InfraWorks General Discussion
Valued Contributor
Harold_Alberto
Message 1 of 11 (678 Views)
Recover a file
678 Views, 10 Replies
10-22-2013 12:05 PM
Is there a way to recover a corrupt infraworks file?
I was working on a model that crashed while I was changing road styles.  When I opened the model back again, I get the error report window.  I have already restarted the PC.  Opening a different model is fine.
Is there a backup file created similar to the .bak file for dwg files?
Thanks.
TRogers
Message 2 of 11 (679 Views)
Re: Recover a file
10-22-2013 12:07 PM in reply to: Harold_Alberto
Infraworks does not use a "file" per se.  It's a database.  Not sure how it could have gotten corrupt.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
TRogers
Message 3 of 11 (678 Views)
Re: Recover a file
What is the error you are getting?
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
Harold_Alberto
Message 4 of 11 (672 Views)
Re: Recover a file
10-22-2013 12:17 PM in reply to: TRogers
It doesn't give any details of the error.  It goes straight to the Error Report sending window after a second or 2 of clicking the model.  It just says "A software problem has caused Autodesk Infraworks 2014 R2 to close unexpectedly"
The error log:
161 [3824]: main.cpp(165): info: logging started in: C:/Users/Harold-Mao/AppData/Roaming/Autodesk/InfraWorks 2014 R2/logs/AIM_2013-10-22_20-08-44_0000.log
163 [3824]: AlxApplication.cpp(706): info: init application locale using: 'en-US'
171 [3824]: AlxApplication.cpp(825): info: Using resource data folder: C:/ProgramData/Autodesk/InfraWorks 2014 R2/Resources
171 [3824]: AlxApplication.cpp(835): info: Using user data folder: D:/Harold-Mao/My Documents/Autodesk InfraWorks Models
1113 [3824]: Core.cpp(41): info: using GDAL data path: C:/Program Files/Autodesk/InfraWorks 2014 R2/\gdal_data
1253 [3824]: AlxApplication.cpp(461): info: AlxApplication: Initialized!
4244 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_CommentsFeed.aimplugin.dll
4432 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_PathOptimizationUI.aimplugin.dll
4716 [3824]: ActionManager.cpp(50): warn: Action 'ID_Window_ProfileView' has already been registered -- will replace.
4717 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_RoadsHighwaysUi.aimplugin.dll
4727 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_RT.aimplugin.dll
4734 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_Scenario.aimplugin.dll
4848 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_Service.aimplugin.dll
neilyj
Message 5 of 11 (644 Views)
Re: Recover a file
10-24-2013 08:53 AM in reply to: Harold_Alberto
Same is happening to me
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Contributor
Harold_Alberto
Message 6 of 11 (604 Views)
Re: Recover a file
10-30-2013 07:49 AM in reply to: neilyj
Neil,
What caused the crash?
I had one again today just changing a road style from the properties palette.  Previously I was drag and dropping a road style from the Style Pallette to the proposed road.  :smileyfrustrated:
Valued Contributor
Harold_Alberto
Message 7 of 11 (600 Views)
Re: Recover a file
10-30-2013 08:05 AM in reply to: Harold_Alberto
I found this thread and followed the steps but didn't work.
http://forums.autodesk.com/t5/InfraWorks/crash-on-start-up-corrupt-file/td-p/3932402
New Member
ian.butt
Message 8 of 11 (591 Views)
Re: Recover a file
10-30-2013 09:34 AM in reply to: Harold_Alberto
If you manage to get your model fixed somehow please let us know. My model corrupted earlier today when my pc bluescreened and i've lost a lot of work because of it.
neilyj
Message 9 of 11 (563 Views)
Re: Recover a file
10-31-2013 05:34 AM in reply to: Harold_Alberto
I'm not sure - I just deleted it all and started again...
neilyj
Member
stevebatchelder
Message 10 of 11 (338 Views)
Re: Recover a file
01-08-2014 10:57 AM in reply to: neilyj
Has anyone found a solution for this yet? I am having the same problem. My crash happened when I was tying to add a data source. Now every time I try to open that model Infraworks crashes.
I have tried logging out, shutting down, opening on another computer, and the process described in: http://forums.autodesk.com/t5/InfraWorks-General/crash-on-start-up-corrupt-file/td-p/3932402 but nothing has worked.
I'm about ready to recreate the model unless anyone has a solution.
