InfraWorks General Discussion
Valued Contributor
jeffmorris
Message 1 of 4 (204 Views)
Railways are red
204 Views, 3 Replies
04-14-2012 06:51 PM
I imported shape file for railways into AIM and they are all red instead of having different materials. How can I fix the problem?
Employee
konstantin.baumann
Message 2 of 4 (198 Views)
Re: Railways are red
04-16-2012 02:04 AM in reply to: jeffmorris
In AIM 2012 we don't have a "Railway style editor"; changing/fixing railway styles would require you to manually edit XML files, which I wouldn't recommend.
In AIM 2013 we have added the missing "Railway style editor", which is very similiar to the "Road style editor" and allows you to create new and modify & fix existing railway styles. If you need help with this please post back and we can figure out what is not working correctly/as expected for your case...
Valued Contributor
jeffmorris
Message 3 of 4 (191 Views)
04-16-2012 01:18 PM in reply to: jeffmorris
AutoCAD has Filter command for selecting objects by type of object such as line, circle, etc. Does AIM have filter command?
Employee
konstantin.baumann
Message 4 of 4 (184 Views)
04-17-2012 05:52 AM in reply to: jeffmorris
Could you please start a new thread for a new topic...
Not sure what you are asking for: each AIM feature belongs to a certain feature type (road, coverage, barrier, water area); you can select all features belonging to a certain feature type via the "Model Explorer"...
In AIM there are no such basic graphics primitives as circles or lines; we are dealing with higher level constructs.
What would be your intended workflow that would require you to select such elements?
Post to the Community
New Post
Need installation help?
