Hello Forum,
I have created a 3d model in AutoCAD (civil 3D 2015) but when i export it to Infraworks 2015 (as fbx and dxf) the files are rubbish (see attached photos) I have also tried to export from Navis simulate and it looks good in navis but rubbish as a FBX.
What am i doing wrong?
All help will be appreciated
David
Hello Forum,
I have many buildings measured with eaves height and roof height. The roofs are displayed as 3D surface and the walls as extrudionierte surface. How can I export the building from AutoCAD to Autodesk Infrastructure Modeler? Thanks for reply.
I have yet a question. I would like to import an aerial imagery and after convert is at 0 meter. Although I have already imported digital terrain model.
Karsten,
It was a scaling problem, but not because the points are to close, but the drawing is to far from the origin in autocad.
I think the fbx export needs to have a co-ordinate shift parameter to allow the models to export to infraworks.
David
the root cause would be the 3d entites are far way from the orgin in the dwg file. To get a better exported FBX file, You can try to
1. move them to a new location near the origin.
2. use the selected entities as below in the FBX export options dialog
Hi klingenstein, I have filed a ticket for the issue of importing the Mesh and Face objects from AutoCAD. So far, I could not get a workaround for it. Both FBX and NWD do not work per my test. Thank you for reporting this issue.
