Mdel looks great in Infraworks 2014. Scenario is added, published using entire model and LOD on high w/ computed ambient occlusions, Tile size:200 Texture size:256. The model in Infraworks 360 for iPad brings in all the detail but is entirely in greay scale, Help!>???!?!
This is the model in a browser from clicking the collaborate tab and clicking manage online scenarios and clicking open with browser
I am currently re-publishing the MODEL and will Publish a scenario, I tried setting LOD to low and nothing helped. The iPad is an iPad 2, viewer is version 15.2.4357
Hello Karsten,
Sorry, I must have deleted the model I published by accident, I was going to send you a link to a new one that is still not working, but I am already publishing the model to the group you sent me. In addition, I notice a jeep .dae from the model (converted from .skp in sketch up) is appearing in the model, but not in the online link nor on the iPad.
Thank you for your help, I hope it publishes by tomorrow.
Model has been loaded, I'll now publish a scenario at default settings (200/256/medium), it will be called Karsten
You have been invited to view the 3D scenario Karsten, created by benraw@shaw.ca using Autodesk InfraWorks 360.
To open the scenario in a browser, click https://infraworks360.autodesk.com/api/account/722c6abab72e11e1b85e123139052002/group/482/scenario/K.... The latest versions of Chrome and Firefox have the built-in WebGL support required to open the scenario. If you are using Internet Explorer you will need to install the Google Chrome Frame from http://www.google.com/chromeframe.
To open the scenario on your iPad, in the Autodesk InfraWorks 360 app, click https://infraworks360.autodesk.com/viewer/iPadLauncher.html?account=722c6abab72e11e1b85e123139052002....
Hello Karsten,
Thank you for looking into this,
I believe I have 2014R1 as I cannot open your model due to it being created in a more "recent version", I will try again after I can find a way to install 2014R2...
Hello Karsten,
I believe you may have published a 2014 model as I now have R2 installed and cannot download your model to republish it. Could you post another/confirm?
Thank you,
Ben
Hi Ben,
I have synchronized the model in the group with a 2014 R2 version and republished a scenario from that version as well.
Karsten.
Whole new problem now. Went to publish a new model I have created, I now have both a Infraworks 360 Pro icon and an Infraworks R2 icon. When I launch both programs, all the local models show up as normal, but when I try to sign in and click on the blue text or the sign in drop down....no window for log in opens, nothing happens. I fear this may have to do with a solution I was told to use when having issues loggin in through Civil 3D, and that was to delete the web services folder in the local appdat folder. This fixed my log in problems for C3D but now I have problems in Infraworks. Or could this be a problem from the R2 install?
Thank you!
I would suggest to wait some time (until Monday) and try later again.
The reason is that Autodesk experienced some server outages for InfraWorks 360 yesterday and the day before. Many users experienced sign in issues yesterday. I hope the issue will be solved soon on the server side and following that your sign issues disappear.
Karsten.
